Fuel pressure and oil pressure
Elmer
Hi, I don't know what to do to make some changes. I have an oil pressure reading of 91 PSI with engine off and fuel pressure reading of 54 PSI with engine off. Is there a way to get them back to zero?
That sounds like a mis-configured sensor or possibly a wire that's going somewhere it ought not to. Give our technical support a call at 425-402-0433 when you have a chance for more personalized help.
Elmer
Thanks Dynon, Yes it was mis-configured sensors. I called Dynon and they told me how to fix it but while I was fixing them I caused another problem. I can only get the Skyview and GPS to come up on the screen. No engine monitoring or transponder. I tried every thing I know. There is something I'm not doing right. Any help will be appreciated.
Elmer
Hard to say what you're seeing without a bit more detail (or pictures). Are you just not seeing the EMS page at all. That can be pulled up by using the SCREEN menu? Or does the EMS page have a red X over it. Same thing with the transponder. What's in the status area for the transponder? Is it just gone? Or red X? Or are you saying that you've lost your way to the XPNDR menu?
Elmer
Hi Dynon, I can only bring up two screens. The Skyview screen and the big red X of the ADS-B screen. I have totally lost the transponter and the EMS screen. I had all the screens until I made some changes to the EMS sensors. I haven't figured out how to use the screen menu, yet.
Thanks for the help.
jacktunnell
I just fired up my Skyview and I'm having a similar problem.
I rang the wires between the Kavlico sensors and the EMS 37 pin on pins 6 (Oil Press) and pin 8 (Fuel Press).
Good continuity from the sensor power to pin 18, sensor ground to the gang ground and to the engine ground, and pin 6 and 8 to their respective sensors.
With power on, I get 5 volts at the Green wire on each sensor as well as 5 volts on the red wire.
I cross checked pin 6 & 8 respectively to ground and to every other pin in the 37 pin plug. There is no cross continuity.
What is the configuration trick please?
