kjmorris2023
- Joined
- Dec 3, 2020
- Messages
- 19
1) We have a Dynon install on an 1979 A-36TC with a TSIO-520 UB turbocharged. Before upgrade FP was 3.2 psi or so idle, about 15.8 psi Max power, and around 6psi LOP cruise. Now with Dynon EMS it's about 4.3 idle, 27.8 Max power and around 7.8 LOP. Other Guru's have mentioned that maybe the transmitter is located in the line prior to the fuel control rather than after the fuel control. Unmetered versus metered fuel pressure. Can you tell me where the Dynon transmitter would be located?
2) At full throttle were getting a fluctuation in the pressure. Plus or minus 4 psi. Steady as a rock at all other power settings. Dynon Tech can you shed any light?
Attaching engine data last flight
