From the installation manual: The fuel pressure sensor port has a 1/8-27 NPT pipe thread fitting; you may need adapters to connect to the pressure port on your engine. Locate the correct fuel pressure port for your engine. This port must have a pressure fitting with a restrictor hole in it. This restrictor hole ensures that, in the event of a sensor failure, fuel leakage rate is minimized, allowing time for an emergency landing.
I am connecting to a Flare 1/4" tube "T" on the IO550N which is not restricted. Where can I find a connector fitting with the appropriate restriction?
Any help would be appreciated.
