Fuel Pressure Sensor - High Reading??
sunfish
I have a rotax 912 iS in a Zenith CH750. I have a Skyview Classic. The aircraft time in service is about 40 hours. I changed the fuel injection pressure sensor from a 101716 - 000 50 psi unit to a 1013757-000 unit supplied by Dynon before first flight last November in accordance with Dynon SB dated June 4 2020.
Last flight I started getting sporadic "high Fuel pressure" alarms (>50 psi). Thinking I may have fuel filter clogging, I prepared to change fuel filters. Before I did that, I checked the system to get a baseline pressure this morning by running the injection pump without starting the engine. The indicated fuel pressure reading was 49.2 psi which is way over the allowable limit of 46.4 in normal operation. When I shut down the pump the pressure did not drop to zero as it should but remained at 5.7 psi. I confirmed this behaviour a few times. I checked the EMS sensor setup and it shows that I selected the correct sensor running in differential mode. I tried changing to a non differential mode and skyview indicated the same thing - 5.7 psi when fuel pressure should be zero. I checked Skyview data from my first flights eleven months ago and fuel pressure returned to zero when the system was switched off. It doesn't seem to do that now. I checked MAP behaviour and it is normal.
Unless there is a physical blockage in the fuel return line, which I have not checked but doubt, or a corrupted sensor file, which I have not checked, it appears that the sensor has failed. I note that subtracting the offset from the indicated pressure puts the fuel pressure where it should be prior to startup at about 44.6 psi.
What else should I do to try and isolate this fault?
Couple of thoughts: If you expose the sensor to atmosphere (take it out of the fuel pressure port), does it still register non-zero? Also, double-check that you definitely have the right part number selected in pin mapping (sounds like you do though).
sunfish
Thank you Dynon for your great follow up!. I've sent an email to you with the following advice.
I haven't checked pressure on the 1013757 - 000 when exposed to atmosphere. What I did instead was plug in my old 101716 - 000 sensor and it showed zero psi just fine.
I reinstalled that old sensor, selected it on the sensor setup page, started the fuel pump and it works exactly as it should. I believe we have a failed 1013757 sensor with a 5.6 psi pressure offset. I've asked in the email about warranty and returns.
sunfish
Dynon followed up and I have a new sensor installed and tested OK. The faulty one is on its way back to Dynon for investigation. Thank you Dynon for great customer service!
