Fuel pressure Sensor Setup
mcnabb
I love flyinga taildragger.
Erwin, TN
I'm trying to setup the fuel pressure sensor. If I set the maximum to 55 it turns red on the display, It will accept 50 without turning red. I'm setting the minimum to 0. I can set different ranges to different parameters with the last range to the top at 50 and the bottom at 45 with the color red. I'm still getting a fuel pressure warning at 38psi. I'm using the UL 130 hp engine in my plane. I'm pushing accept after each entry. any suggestions will be appreciated.
You have a 50 PSI sensor, so you can't set any of the numbers above 50, because the sensor can never read above that. If you need to display pressures above 50, you need to move to a 75 PSI sensor.
Ahh, sorry for the misunderstanding.
Do you have more than one red range defined by any chance?
Have you tried turning off the alarm for the fuel pressure and made sure the alarm stops, just to be sure it's the correct alarm?
You could send us a screen shot, picture, or your config file so we can figure it our quickly.
mcnabb
Erwin, TN
Thanks, I might have one red range on Range #1, I will check when I return home!
mcnabb
Erwin, TN
Thanks I changed the first range to 0-45, and the second to 45-50. This took away the warning message. I appreciate your help!
