Fuel pressure sensor
bdirdal
Jabiru 170 owner
Where is the best place to intall the senso on a Jabiru 2200 egine?
Should it be installed between the engine fuel pump and the carburettor?
Regards
Borge :)
That's what I do - then you will know if the engine pump is losing pressure and also when the electric pump is turned on you will see the pressure increase confirming it works too.
Jake J
JR
Yes thats the right location but problem is the pressure in a Jab is way too low for these senders to work well.
Also I think the internals arnt that suited to fuel and dont last long. Mine spent its short life reading poorly and has now stopped.
I have raised the issue with Dynon, and they believe there is no low pressure sender solution.
I am eventually going to give the Stewart Warner one a go.
