fuel sender compatibility
blueflyer
I see that the D100 says its compatible with most resistive type fuel senders, but i thought I would ask about a specific one before I purchase it.
Will this fuel sender work with a D100? Its from wicks aircraft. The description says:
"MechanicalFloat-type fuel sender with 10-180 ohm resistance (empty to full) for use with like-resistance gauge (ex. MAI-301015). Mounts either horizontally or vertically in 6-19" deep tanks using std SAE 5-hole bolt pattern. Includes gasket. 12V. Wt: 12 oz. New installation requires #226-451 installation kit. FAA-PMA approved. Mitchell Aircraft Products"
