Garmin 496 to D-10A question
jreekree
Am I correct in assuming that when I want to display nav and wind info from my Garmin 496 that I connect the blue wire from the 496 harness that is data out to pin 22 on the D10A?
From both schematics that appears to be correct but I wanted to check and see if there is another pin I have to connect.
I did build a USB/Serial cord and also connected that data in wire to pin 22 and it worked to upload the software updates.  I have installed a switch so I can use the same pin and connect it to the GPS.
Any advise would be appreciated.
Jerry Morris
