Garmin GNC 300XL Compatability
rockyjs
Navarre, FL (AL55)
I just purchased a FD-180. I planned on using a Garmin 300XL and recently got a quote. I was informed " For the Gnc-300xl to be IFR you will need full CDI capability which may be available through Dynons new ARINC box ". Can anyone fill me in on what CDI compatibility using a NMEA feed from the Garmin
When an IFR GPS is hooked up to a nav head via either the ARINC-429 or analog connections (which the HS34 supports), and you're flying an approach, the CDI's sensitivity gradually increases as you get closer to the airport. This happens in a smoothed, stepwise fashion, automatically as you transition between enroute, approach, and terminal distances from the airport.
In contrast, NMEA data is not really designed to be the data source that drives a nav head. It provides course and cross track error, which is enough to draw an HSI, but isn't enough to provide the auto-scaling CDI needles as described above (and in your GPS's users manual). You CAN toggle between enroute, approach, and terminal sensitivities manually on the Dynon when using a GPS without the HS34, but the question ends up being - do you really want any more workload items when you're flying a real IFR approach?
Our general reccomendation is - if you're planning on using your IFR GPS in actually IFR situations, and want the book-specified behavior from your CDI indicator, you probably want to interface that GPS through the HS34 (or use an external nav head). If you're using your Dynon HSI informational purposes only in a non-IFR environment, the ARINC-429 and analog interfaces may not be as important to you.
rockyjs
Navarre, FL (AL55)
Thank you for the reply. On the topic of the HS34 I have seen in a post that you are offering the HS34 in a horizontal model. I could not find any info on this. Is the footprint the same, just turned sideways, or does it have different dimensions? I've mounted my FD-180 tray and saved space underneath it, but would like to know if I have enough room there. Thanks
The horizontal version is identical, but rotated 90 degrees clockwise.
