Garmin GNC215 vs Trig TX 56?
cbretana
I am redoing the panel in my aircraft, from old steam gauges to a full Dynon Suite based on Skyview HDX, and I want to include a second COM/NAV radio (in addition to the Dynon Transceiver).
I have done some research, but I would like to hear other's opinions about whether I should go with the Garmin GNC 215, or the Trig TX-56. They both can use the SL30 protocol, so should be compatible with Skyview through one of five serial interfaces...
Carl_Froehlich
No brainer - the Trig. Better company and better radio.
In my other builds I did the Garmin GTN-650 and the Dynon radio (made by Trig). On the current build I looked hard at the Trig TX-56 paired with the Garmin GPS175 instead of the 650. It boiled down to the GTN-650 again as I got a better deal on the components.
I would do some checks on the GNC 215 being compatible with the SkyView display (as in you can see GNC 215 frequencies on the SkyView, not just the ARINC interface). I know the Trig does this but I’d be surprised if the GNC 215 can.
Carl
ve0kog
I'm curious about this as well. How does skyview handle sending frequencies to the second radio (whether SL30/GNC215 or Trig)? I'm kind of addicted to the APT->Com button to populate shortcuts in the primary Dynon radio from the INFO page.
Is there any way to send COM or NAV frequencies to COM2 from the HDX?
