matt.hocker
- Joined
- Jan 16, 2013
- Messages
- 15
I have a Dynon EFIS-D100 and a Garmin GTX 327 transponder. The transponder currently uses its own dedicated altitude sender which works fine but occupies a space behind my panel that I'd like to use for a steam gauge VSI.
I read the manual for the D100 and the GTX 327. It appears that I can input gray code altitude input to the Garmin by connecting pin 13 of the D100 to pin 19 of the GTX 327. The D100 apparently can be configured to output the correct serial data using "Format 4" which the Garmin requires.
My question is, other than freeing up the space from the altitude encoder, are there any pros/cons of using this setup versus a dedicated encoder?
