General contact display error
cnail1982
I have contact 1 wired to the dynon heated pitot. When it is off it is programmed to display "OFF" but instead shows "O O". It shows "on" correctly when on. I have tried two variations (left and right justified) with the same result. Any thoughts?
Hi Christopher. Could you send us a screenshot of that behavior as well as a .dfg from a SETTINGS EXPORT?
cnail1982
My apologies. It's off the ems and I posted in the efis area. Attached is a picture. Notice the contact with the "o o" above and heat below. How do I get a settings export?
Try changing the contact state that's programmed to "OFF" to some other characters. Say something simple like 1234. Then exist setup and see if this changes the off state to those characters. If it does, then change it back to OFF. Any joy?
