Will the 3 GP inputs on the Dynon 120 work without the HS34 I have set two up to monitor CHT on my Rotax and wanted to use the third one for coolant temp.
Yes, without the HS34, you've got 3 GP inputs to work with. With a 912 in the mix, two of them are used for the CHTs, so you're left with one to use elsewhere.
