Glasair II Rochester Fuel Sensors
I have a Glasair II with what I believe to be standard Rochester fuel sensors. I bought the plane used so I don't have documentation. Has anybody connected these sensors to Skyview and what would be the proper method.
The sensors have two wires. One was connected to the GND lead on the gauge and the other (center lead on sensor) was connected to the SEND lead on the gauge. Do I GND the GND lead from the sensor and connect the other sensor lead to a General Purpose (Enhanced) wire on the SV-EMS-220 (pin 8,22 or 31)?
These should be standard resistive senders that work fine with our products. Just wire them up as described in the manual (to any EMS GP pin, doesn't have to be enhanced).
You just need to ground the ground lead and run the other one to a pin on the EMS module.
