I think there may be a glitch in the EMS software. I have a single fuel tank with Red Cube flow sensor but no fuel level probe (such as a capacitance or float style probe). After refueling I turn on the skyview, adjust the fuel level manually, and then power off all the avionics using the master switch. The next time I power on the skyview the fuel level has reverted back to the previous value, not the recently-reset full value.
After setting the new value, I'm backing out to the main menu, and the display shows the right value until I power the unit down (usually in just a few seconds, though).
It seems like the skyview needs some time to "save" the new value, or needs the engine running, or a fuel flow reading, or something? This might be a good fix to work into the next update.
Thanks guys, and keep up the good work!
Jeff
Jeff
