GNS-430 Output Settings
meljordan
Tucson, AZ
Tim,
I replied to your PM several days ago, guess you didn't check your Dynon messages. Anyway, set your 430 the same as for the G1 products, Aviation format and 9600 baud. Then set the SkyView for "Garmin 430" input and they communicate just fine. Of course, remember that you have to tell the SkyView to use that GPS in the serial setup by turning off the other serial inputs.
Best,
Mel
timfwalsh01
Alexandria, VA
Mel,
Thanks for the response(s).
I am scratching my head trying to figure out why this is not working.  I confirmed all the GNS-430 output settings (same as previous settings  for EFIS D10A).
The 430 is transmitting data.  All other serial ports turned off.
Guess I will need to talk to Dynon support.  Thanks  Tim
