GPS antenna
goobermax
Hi - I just ordered a SV-10" system to replace my BM EFIS one. Will my GPS antenna from that old system work with your system or do I need to buy one from you? If it is just a connector difference can I just change out the connector?
Thanks - Jeff
Our system doesn't use an antenna- the GPS receiver is inside the thing that goes outside the plane.
So basically, no, you can't reuse it.
You can use any GPS with SkyView - a Garmin 396, a Lowrance 200C, a Garmin 430, whatever. Or you can buy our GPS receiver.
Yes, something like the Garmin 35 will work if it's the serial version. What we sell is effectively a modern version of this that is 5Hz, WAAS, and environmentally designed to be outside of an airplane.
