GPS fed CDI functions
Ken_Kopp
Wellington Aero Club (FD38) FL
Can I interface my GNC-300XL directly to the Skyview and have full HSI/CDI functionality via serial? Future ARINC?
If not, if I connect the 300XL to my HS34 via ARINC can I then connect the skyview to the HS34 via serial and have the required CDI functions for IFR approaches?
Thanks!
Ken
Ken_Kopp
ok I'm kind of thinking out loud here...
My setup as follows:
Skyview with skyview GPS
D10A as a B/U EFIS and dedicated HSI head
GNC300XL approach GPS
GTX330 XPDR
As I understand things as they are now I can connect the 300XL to the Skyview via serial and choose between the skyview GPS and 300XL
I could then connect the 300XL to my HS34 via ARINC and to the D10A via DSAB to obtain full HSI/CDI functionality?
I would like to use the D10A as a B/U altitude source for the GTX 330 XPDR. I'm planning on using a switch to select between the skyview and D10A for altitude reporting. Any issues with this?
All ok? Thanks! Ken
TRCsmith
Suisun City, CA
As I have read earlier that it can't be used with Skyview. Now you're saying that the HS34 can be used with Skyview, Or SOoo, you're saying it can in such a way be used??? :eek:
Ken is only planning on using the HS34 hooked to the D10A. It will not work with SkyView.
Ken, you can install a switch for the altitude encoder. No issue. I also don't see why serial to the SkyView and ARINC to the D10A won't work.
You can never had "full" CDI functionality from a panel mount GPS without ARINC. None of them send out the CDI dynamic scaling over serial. But you do get most of the functionality over serial, once we have a functional HSI in SkyView.
