rvbuilder927
- Joined
- Jul 18, 2008
- Messages
- 8
I am trying to connect my D10A to a Garmin GPS III Pilot. It appears that others have done so successfully, but I can't seem to get the Dynon to recognize the GPS. I have the GPS set to output NMEA at 4800 baud (the only rate choice). I have tested the wiring. The Dynon has been updated thru the same female DB9 and worked fine. I have double-checked that the GPS transmit wire is inserted into pin 3 on the new DB9 connector. I have tested for continuity from the plug in the back of the GPS to the pin 3. The Dynon HSI EFIS-Serial is set to NMEA, 4800, but on the HSI setup screen, the list of 9 GPSs does not show any inputs, and the clock on the Dynon does not sync to the GPS clock, and the HSI only shows heading.
I assume that the list of 9 GPSs on the HSI setup screen should show input from one GPS? How else will I know that they are "talking"?
Sorry about the long-winded post.
Any help would be MUCH appreciated.
Ward :-X
Ward :-X
