GPS Mounting
dpbarnes
Schererville, IN
I have the Dynon GPS wired to Skyview and a Garmin GPS-18 OEM wired to Skyview as a back up and also to an ELT and my Vertical Power VP-200. All works fine but since I am still building the units are remoted outside so they can see the sky. What my question is will the two GPS's interfere with each other when mounted on a shelf underneath the skin of my fiberglass airplane? If so what distance do I need between the units?
They should be fine at any distance, just as long as they're not covering each other's view of the sky. GPS receivers are low power radio receivers, fundamentally.
