The EFIS-D10A will output wind speed and direction if a suitable GPS NMEA feed is enabled. The details are given on
http://wiki.dynonavionics.com/GPS_Serial_Compatibility_and_Configuration_Settings
These state a requirement for sentences GPRMB and either GPBOD or GPAPB.
However all the above sentences refer to routing
http://www.gpsinformation.org/dale/nmea.htm
Why cannot the EFIS give windspeed and direction with more limited GPS input such as from my FLARM which has the following NMEA output?
http://www.flarm.com/support/manual/FLARM_DataportManual_v4.01E.pdf
Regards
Rory
Regards
Rory
