I've got an older GRT map sensor permanently wired in to the airframe. It uses 12V instead of 5V and is wired in parallel with other 12V sensors. In other words, I'd have to run new wires to run the Dynon MAP sensor.
So, I'd like to get it working properly, if possible. I also have a spare. No part number is visible on it. It simply says
"manifold pressure sensor 5-31Hg
manufacture date 11-99
Aux SF = 141 AuxOff = 86
1=12V, 4=output, 5=ground
Grand Rapids Technologies, inc"
It shows 56 inches of MP here at sea level. And the numbers change downward as I draw a mouth vacuum on the sensor.
Thoughts? Suggestions?
Thanks!!
Thanks!!
