guide to dfg file terminolgy and format?
ssbn608
Boerne, TX
We are trying to setup the Dual SkyView display in our Pipistrel Virus SW (from kit) with Rotax 912iS. We received sfg and dfg files from Pipisrtel.....but they used metric units. We also downloaded EMS_912_iS_120414_kav.dfg from the Dynon website.
With one of these files, our fuel pressure works, but our electric trim indication doesn't. With the other dfg file loaded, the electric trim indication works, but the fuel pressure doesn't .
We opened each of the dfg files in Microsoft Notepad, hoping to copy electric trim indication setup info from the file in which it works... to the file where it doesn't.
But...the format of the files is quite different. The Pipistrel file has a number of introductory lines where they seem to be assigning some initial values (like last latitude and longitude, or tail number, or units of measurement) before they get to pin assignments and widget info. The Dynon dfg file looks very different. And we can't really figure out which part I need to copy from the one file, to replace the corresponding but non-functioning part of the other file.
I'm going to paste an initial portion of the Pipistrel file below, so you can see what I'm saying, but my main question is this: Is there any documentation of the setup, language, and formatting of the dfg files. There's something posted about making your own sfg files, which discusses the formatting of the entries in those files, but I haven't seen anything like that for dfg files.
I mean, simple things like Valid=1 or Valid=0 . When would you use those? if something wasn't valid, why put it in the dfg file?
It seem to be some sort of programming language...but which one? Where can I find information on how to program...required format? required /permissible commands? etc.
As promised, here's the beginning part of the Pipistrel file. (Obviously, not mine to give away wholesale, not verified by me, and for reference only to facilitate this discussion, and not for flight use)
operational_time=232879
portsel_ahrs=INSTR_PORT_REMOTE
portsel_ahrs_roll=INSTR_PORT_REMOTE
portsel_ahrs_pitch=INSTR_PORT_REMOTE
portsel_ahrs_heading=INSTR_PORT_REMOTE
portsel_ems=INSTR_PORT_REMOTE
portsel_position=INSTR_PORT_NONE
last_known_lat=45.887577
last_known_lon=13.890728
last_known_alt=113.644
units_temp_oat=UNITS_TEMP_C
units_temp_other=UNITS_TEMP_C
units_press_other=UNITS_PRESSURE_BAR
units_press_man_v5=UNITS_PRESSURE_MANIFOLD_INHG
units_speed_v11=UNITS_SPEED_KTS
units_distance=UNITS_DISTANCE_NM
units_alt=UNITS_ALTITUDE_FEET
units_baro=UNITS_BARO_MB
units_volume=UNITS_VOLUME_LITER
units_fuel_eff_lkm=0
time_zone=STD -01:00
ser_in_dev1=SERIAL_IN_DEVICE_NONE
ser_in_dev2=SERIAL_IN_DEVICE_FLARM
ser_in_dev3=SERIAL_IN_DEVICE_ATR833
ser_in_dev4=SERIAL_IN_DEVICE_XPNDR_262
ser_in_dev5=SERIAL_IN_DEVICE_DYNON_GPS
ser_in_dev6=SERIAL_IN_DEVICE_NONE
ser_out_dev1=SERIAL_OUT_DEVICE_NONE
ser_out_dev2=SERIAL_OUT_DEVICE_NONE
ser_out_dev3=SERIAL_OUT_DEVICE_ATR833
ser_out_dev4=SERIAL_OUT_DEVICE_XPNDR_262
ser_out_dev5=SERIAL_OUT_DEVICE_NONE
ser_out_dev6=SERIAL_OUT_DEVICE_NONE
ser_in_func1=SERIAL_IN_FUNC_NONE
ser_in_func2=SERIAL_IN_FUNC_TRAFFIC
ser_in_func3=SERIAL_IN_FUNC_NONE
ser_in_func4=SERIAL_IN_FUNC_XPNDR
ser_in_func5=SERIAL_IN_FUNC_POS1
ser_in_func6=SERIAL_IN_FUNC_NONE
serial_name1=
serial_name2=
serial_name3=
serial_name4=
serial_name5=
serial_name6=
ser_baud1=SERIAL_BAUD_9600
ser_baud2=SERIAL_BAUD_19200
ser_baud3=SERIAL_BAUD_9600
ser_baud4=SERIAL_BAUD_38400
ser_baud5=SERIAL_BAUD_38400
ser_baud6=SERIAL_BAUD_9600
arinc1={
serial_num=6387
product_id=DYNON_PRODUCT_ID_NONE
input_speed=HIGH
input1=SERIAL_IN_FUNC_NONE
name1=
input2=SERIAL_IN_FUNC_NONE
name2=
output_speed=HIGH
allow_auto_switch=1
arinc2={
serial_num=8033
input_speed=HIGH
name1=
name2=
output_speed=HIGH
allow_auto_switch=1
active_nav_src=SERIAL_IN_FUNC_NONE
brg1_nav_src=SERIAL_IN_FUNC_GPS1
brg2_nav_src=SERIAL_IN_FUNC_GPS1
brg1_is_sby=0
brg2_is_sby=0
active_fpl_src=SERIAL_IN_FUNC_GPS0
xpndr_code=02000
xpndr_cmd=SBY
xpndr_vfr=0
squelch=50
mic_gain_v6_2=50
sidetone=5
left_knob=KNOB_SELECT_HDG
right_knob=KNOB_SELECT_ALT
disp_trip_sub=TRIPLE_PFD_EMS_MFD
disp_pfdmfd_sub=DUAL_MFD_PFD
disp_pfdems_sub=DUAL_50_50_PFD_EMS
disp_mfdems_sub=DUAL_50_50_MFD_EMS
disp_mfdpv_sub=DUAL_MFD_PV
disp_vid_sub=DUAL_X_VID
disp_state_v5=PFD_EMS_STATE
video_state=PFD_STATE
normal_pfd=SCREEN_OP_SAVE
normal_ems=SCREEN_OP_SAVE
normal_map=SCREEN_OP_SAVE
allow_layout=1
allow_swap=1
allow_reversion=0
reversion_trip_sub=TRIPLE_PFD_EMS_MFD
airplane_icon_type=AIRPLANE_ICON_TYPE_DEFAULT
reversion_pfdmfd_sub=DUAL_PFD_MFD
reversion_pfdems_sub=DUAL_50_50_PFD_EMS
reversion_state=TRIPLE_STATE
tail_number=SW 100
total_flight_time=1547
landing_gear_type=FIXED
gear_warn_speed_high=150
gear_warn_speed_low=80
xpndr_hex_code=0x123456
xpndr_vfr_code=01200
xpndr_squat_switch=SQUAT_SWITCH_NONE
xpndr_ac_category=XPNDR_CAT_LIGHT
xpndr_ac_length=6.096
xpndr_ac_width=7.62
xpndr_cruise_speed=CRUISE_150_300
xpndr_gps_format=XPNDR_IN_TMAP
xpndr_cdti=XPNDR_CDTI_NONE
xpndr_tis_on=1
adsb_tfc_xpndr_required=1
pri_radio_device_v11=PRI_RADIO_DEV_SERIAL
pri_radio_id=INSTR_PORT_SERIAL_3
display_pri_radio=1
com_833khz=1
nav_radio_pid=DYNON_PRODUCT_ID_NONE
nav_radio_sn=0
nav_radio_1_func=SERIAL_IN_FUNC_NONE
nav_radio_1_name=
user_data_log_rate=LOG_RATE_8_0_HZ
clock=ZULU
dim_source=DIM_SOURCE_EXTERNAL
dim_user_offset=0
dim_manual1=600
dim_manual2=450
dim_manual3=300
dim_manual4=150
dim_manual5=1
dim_external1=7
dim_external2=5.5
dim_external3=4
dim_external4=2.5
dim_external5=0.9
flight_time=1547
flight_trip_time=1547
engine_time=0
engine_trip_time=0
timer_up=1
timer_last=0
audio_vol=50
audio_bal=50
audio_sound_boot=1
audio_sound_aoa=TONE_THRESH_MED
audio_aoa_vol=100
audio_aoa_ias_min=10.2889
audio_alert_vol=100
audio_sound_gmeter=SOUND_MODE_VOICE
audio_sound_traffic=SOUND_MODE_VOICE
audio_sound_traffic_lost=SOUND_MODE_VOICE
audio_sound_apconn=SOUND_MODE_VOICE
audio_sound_apdisc=SOUND_MODE_VOICE
audio_sound_apother=SOUND_MODE_VOICE
audio_sound_overspeed=SOUND_MODE_VOICE
audio_sound_altalert=SOUND_MODE_VOICE
audio_sound_flaps_overspeed=SOUND_MODE_VOICE
audio_sound_timers=SOUND_MODE_VOICE
audio_sound_ems=SOUND_MODE_VOICE
audio_inhibit_ems_at_boot=ALERT_INHIBIT_YES
audio_sound_nav=SOUND_MODE_VOICE
audio_sound_sys=SOUND_MODE_VOICE
landing_alerts_audio=SOUND_MODE_VOICE
touch_kb_layout=A_THRU_Z
wifi_saw_device=0
wifi_enabled=0
wifi_hide_network=0
wifi_enhanced_dhcp=1
parameter_locking={
EMS_LAYOUT_LOCKED=0
EMS_INPUTS_LOCKED=0
EMS_VALUES_LOCKED=0
ENGINE_INFO_LOCKED=0
SERIAL_PORTS_LOCKED=0
ARINC_429_LOCKED=0
BRIGHTNESS_LOCKED=0
VP_X_LOCKED=0
V_SPEEDS_LOCKED=0
G_METER_LOCKED=0
TRANSPONDER_LOCKED=0
AP_CONFIG_LOCKED=0
ALT_UNIT_LOCKED=0
SPEED_UNIT_LOCKED=0
TEMP_UNIT_LOCKED=0
OAT_TEMP_UNIT_LOCKED=0
BARO_UNIT_LOCKED=0
PRESSURE_UNIT_LOCKED=0
MAP_PRESSURE_UNIT_LOCKED=0
VOLUME_UNIT_LOCKED=0
FLIGHT_TIME_LOCKED=0
FLIGHT_ANGLE_LOCKED=0
VSI_SCALE_LOCKED=0
FPM_LOCKED=0
PITCH_WARN_LOCKED=0
AOA_LOCKED=0
AUDIO_LOCKED=0
SCREEN_LAYOUT_LOCKED=0
DATA_LOG_LOCKED=0
DISP_RADIO_LOCKED=0
SIXPACK_ALLOW_LOCKED=0
WIDEANGLE_ALLOW_LOCKED=0
DISTANCE_UNIT_LOCKED=0
battery_installed=1
bad_shutdown=1
low_battery_voltage=0
battery_test_date=00-00-0000
battery_test_length=0
video_input_v2=VIDEO_FORMAT_UNCONFIGURED
video_flip_h=0
video_flip_v=0
touch_saw_device=1
touch_enabled=1
touch_show=0
bug_spd_on=0
bug_alt_on=1
bug_hdg_on=1
bug_vs_on=1
bug_mda_on=0
bug_crs_on=1
v_speeds_set=1
pfd_vs0=18.0056
pfd_vs1=22.1211
pfd_vfe=36.0111
pfd_vno=69.45
pfd_vne=83.8544
pfd_va=48.3578
pfd_vx=29.8378
pfd_vy=39.0978
obs_red=100
obs_yellow=1000
ias_on=1
alt_on=1
vsi_on=1
hsi_on=1
oat_on=1
aoa_on=1
fpv_on=1
da_on=1
tas_on=1
vsi_scale=2K
synvis=ZOOM 1
wideangle=0
video=0
gmeter_scale=GMETER_10G
gmeter_neg_red=-3
gmeter_neg_ylw=-1
gmeter_pos_ylw=3
gmeter_pos_red=4
gmeter_on_pos=2
gmeter_on_neg=0
gmeter_reset=1
run_alt_algs=0
wind_on=1
gspd_on=1
gmeter_on=0
pitch_warn_on=1
max_az=-1.0008
min_az=-0.989643
alt_capture_thresh=152.4
alt_deviation_thresh=60.96
pfd_layout_mode=ALLOW_SWITCHING
sixpack_enabled=1
sixpack_debug=0
wideangle_mode=ALLOW_SWITCHING
vne_as_tas=0
baro_mismatch_warning=1
active_ahrs=6915
active_ahrs_prod_id=10
ahrs_oat_adjust=0
ahrs_module={
cfg_count=3
product_id=DYNON_PRODUCT_ID_AP_SERVO
serial_num=6387
alt_adjust=0
hdg_adjust=0
az_offset=0
has_pitot_adjust=0
aoa_valid=0
aoa_gain=1
aoa_offset=0
flap_aoa_cal={
valid=0
gain=1
offset=0
flap_pos=0
flap_aoa_cal={
valid=0
gain=1
offset=0
flap_pos=0
flap_aoa_cal={
valid=0
gain=1
offset=0
flap_pos=0
flap_aoa_cal={
valid=0
gain=1
offset=0
flap_pos=0
flap_aoa_cal={
valid=0
gain=1
offset=0
flap_pos=0
flap_aoa_cal={
valid=0
gain=1
offset=0
flap_pos=0
pitot_adjust=0.000000
oat_adjust=0.0000
pitch_adjust=0.0000
mag_cal_coeff=16777216
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_coeff=0
mag_cal_quality=0
Although the configuration files are human-readable, and contain many easy to understand settings, there are some things that are non-intuitive to even fairly technical users. They're not really designed to be hand-edited to the degree that you're trying to. There also isn't robust documentation available, and as you're finding, they don't fully self-document. For the end-user, they're best used for tweaking values than transporting major settings between files. That said, which file has the working fuel pressure, and which has the working trim indication? Generally, trim calibration is aircraft-specific, so you really want to do that per aircraft. It might be best for you to send the pipistrel file to us at support at avionics dot com along with what you're trying to do with it so that we can help you more personally here.
Back
