Heated AOA/Pitot
b52sfamily
Hey Dynon guys... For us in the planning stages could you update your install specifications manual to show where the wires exit the heater controller box? Additionally could you specify how long the wires run from the box to their connectors and then from the pitot connectors to the pitot itself. All this will help with determining if additional wire runs are necessary and actual box placement in tight spaces. Thanks Guys!
The current diagram in the manual is mostly correct. They're in two bundles, on each "long" side in the center, grouped as indicated. Does that help?
