A few months ago I purchased a Jabiru with a D1000, but the flow meter (FT60) has never worked. Investigations showed the following:-
1) Only 0.5v on the red power supply to the flowmeter.
2) Traced the wire back to the EMS D37, and it is connected to pin 1 not pin 15, and there is continuity from the pin to the flowmeter.
3) The yellow flowmeter signal wire is connected to pin 2, and again there is continuity.
4) Pins 14 and 15 appear to connect to the D1000, but I've not actually traced them. They are also yellow and red wires respectively.
5) The flow meter is mapped to pins 14 and 15.
Questions -
a) Is this simply wrong, or could there be a reason for this?
b) Is it simply a matter of swapping pin 2 and 14 and pin 1 and 15? (But I'm concerned that there appears to be virtually no voltage on pin 15)
c) If b) is the way forward, what pin removal tool do I need?
c) Alternatively, would it be easier to map the flowmeter to pins 1 and 2?
Many thanks for any help.
Jim W
Questions -
Jim W
