Help needed what column in the data file is carburetor temperature
I'm looking to check a flights carb temp but going through all the columns in the EMS (10) file I can not find any sensor which is telling me it's the carb temperature.
Any help what the header for that sensor is?
Thanks a lot
Werner
Dynon support any help on that? Looking as well on how many entries max can be held in the EMS 10 (right now 10 sec intervall) would like to have shorter sampling time (5 or 2 sec)
It should be under whichever of ems gp 1, ems gp 2, or ems gp 3 that it is assigned to.
The entries are limited by the memory capacity and not by any fixed limit. I can't find anything that documents what each of the capacities are for the D10/D100 series, though. But, for example, changing the interval from 10 seconds to 5 seconds would halve the available "time" available in the log, while doubling the amount of entries per unit time. You'd have the same amount of entries when it fills up (and after that, it' will discard the oldest data and keep recording new)
