I have a D120 & D100 for my Rotax 912uls. I've installed the 0-30psi fuel pressure sensor supplied with the rotax kit for the D120 as per the installation guide.
When I check the D120 fuel pressure reading against a calibrated gauge in the fuel system the Dynon is under reading.
When the actual fuel pressure is 0.15 bar the D120 displays 0.09 bar, when the actual fuel pressure is 0.21 bar the D120 displays 0.15 bar.
Is there any way to correct the D120 reading?
