Help!!
Butt
Hi Guys,
putting together my panel. Have a d100,d120,avmap ekp iv,garmin 150 and sl30. Need some advice on how to hook 'em up together to get the most out of them.(dynon :-/ ). Being a novice at this ,just need some ideas. Thanks in advance.
regards
Hook the two DSAB wires between the D100 and D120. This will share all data between the two Dynon units.
You can only hook up two external units to this system, so you need to choose between 2 of the three. You hook one to the EFIS and one to the EMS, and then you can display that information on the HSI page on any screen.
You can also use a switch to choose between two units, so you could install an external switch and use it to switch between the 150 and Avmap if you wanted.
