Ideally, the servo arm and control connection should be in the same plane and at 90 degrees to the axis of rotation of the servo arm shaft with no offset.
If this is not the case then there will be a bit of thrust and pulling vertically on the servo shaft.
The manual says a spacer up to one inch can be used to get things in line.
How much angle between servo shaft plane and pushrods will the servo tolerate?
