Hi,
I have an inductive RPM sensor (113 pulses), how should I connect the 2 wires of the sensor on the SV - EMS-220.
It gives 60 Hz / 300 mV, 1 Khz / 4.5V, 5 Khz / 11V
My engine is a diesel Wilksch
I connected 1 wire on pin 34 "Low voltage input" and the second wire on the ground. With 113 pulses, the tachometer is wrong, with 32 pulses it is more realistic but it is not stable.
What do you advise me to do to stabilize the tachometer?
