How to display one CHT and one EGT only
Camillo
Hallo. Subject is self explaining.
I only installed 1 probe per type without cutting the others, for future extensions.
In the EMS configuration menu is possibile to display or not the "package" of 4 probes, but I can't find the way to tell him to dispaly only cylinder 3 informations.
I couldn't find the answer in the pilot manual nor in the installation manual (but I read quickly the latter).
Sorry if the question is already answered but couldn't find the answer on the forum.
Thanks.
Camillo
Are we talking about SkyView or an EMS-D10/D120/FlightDEK-D180?
If SkyView, you can remove the channels you're not using via the pin mapping EMS configuration page, and the EGT/CHT graph will self-adjust depending on the amount of EGTs and CHTs that are defined.
If it's a EMS-D10/D120/FlightDEK-D180, you can get it down to 1 CHT and 2 EGTs in the global setup menu. From there, you can split the outputs of your single EGT and send it to the inputs to both EGT1 and EGT2. You'll see two EGTs on the display but they'll move together as one.
Camillo
Yes, it is a SV system.
So, in the setup menu, I have to go in the "sensor mapping" section and remove the probes not in use.
Will try.
Thanks.
Camillo
