How to set up teh RAC 12 possition sensor
n40cz
I have the RAC -12 position sensor I want to connect to pin P37-10. When I go to sensor mapping I can make pin 10 set for position, Position and flaps. The when I go to sensor set up I can not fined the flaps i just mapped to configure the sensor. Here are my questions. How do I add a sensor to pin 10 and how do you configure the RAC 12 to read in an arch stlye display?
I believe that you have to calibrate the flaps before they will show in the display setup, p7-49 of the install manual.
SETUP MENU > HARDWARE CALIBRATION > EMS CALIBRATION
So you do need to do as mmarien says above, but also, after you've gotten the pin mapping done (sounds like you have that part taken care of), you also need to add the widget to the 20%, 50%, and/or 100% page(s) you want to see the position widget displayed by going to the SCREEN LAYOUT EDITOR menu.
