HS-34 Power On Problems
khorourke
I recently completed the installation of all my dynon avionics. I have an EMS-D10, EFIS-D10A, EFIS-100 and an HS-34. I turned on the master and everything powered up fine, except the HS-34. then after a few minutes it came on for no apparent reason. When I powered off the master and turned it back on, no HS-34. Sometimes it comes on a few minutes later, sometimes never. Once it comes on, it stays on until I power the bus down. I checked pins 4 (power) and 17 (ground) and they are fine. I am using the Approach FastStack cables.
Any ideas?
Kevin
ericd
Hi Kevin,
It sounds like you may have some power issues with that HS34 that we may need to have a look at.
Please contact us at 425-402-0433 and ask for Eric to arrange this RMA.
Tech Support
