hs34 and gnc 300xl
vinhvinh
Hi. I have a efsi d100 and a ems d120. I will put my panel IFR in the next month. I order a gps GNC 300xl and i will probably order a HS34. My question is thal the GNC 300xl have ARINC output data but also can receive arinc data input. In your installation manual with the gnc 300 you just show to connect the arinc output of the GPS and not the ARINC input.( with the 430 you show to connect both)
With the annunciator of the GNC 300xl, if we push on HOLD button, the next waypoint will act like a vor and we can select an radial with an conventional external HSI that will send the info to the GPS. If I connect the ARINC data in ( hs 34 to gps) will I be able to select the radial with the HS34?
Thank you
Lan Vinh DO
This works on the Garmin 430, so we expect it will work on the 300XL, but we haven't tried it yet. Please try it out and let us know. If the 300XL follows the ARINC-429 standard, it should work.
ghostriver
Alberta
In the "D100 to Garmin xl300" topic, I outlined my experience with the 300XL installation. My post was dated 21 Feb 08. The 300XL is fully functional since then. Hope this will help.
Cheers Bob
