HS34 ARINC 429 Input and Output Words
mr.jadkowski
I'm looking to use a D100 with HS34, as well as a Garmin 430W, to drive a Trio Pro Pilot autopilot. In discussions with Trio, they have stated that EFIS systems with ARINC 429 outputs can be used to control their system. I know the HS34 has one ARINC 429 transmitter port, but I need to know which data labels it will output. I have seen the page on the wiki that covers this, but there is conflicting information on other pages in the wiki that cover the HS34.
What I would like to do is use the heading and altitude bugs in the Dynon system to select headings and altitudes for the autopilot. I would also like to route the GPSS and GPSV commands from the 430W through the HS34 to the autopilot, to eliminate having to switch my autopilot input back and forth from the Dynon to the 430W. So, what I need to know is all the data labels that are transmitted out by the HS34 and their associated values (as represented on the D100 interface), and if any data is passed through from other input sources (in my case, the 430W) for output through the transmitter port.
Alek
Maybe this is useful ? http://wiki.dynonavionics.com/Generic_ARINC-429_Wiring & other info from DS -- "Note that you can only have one device send data to the 430 at once. So if that's your Honeywell EFIS, with the 430's IN set to HONEYWELL EFIS, there's no way to also connect the HS34 to send information to it simultaneously. That's OK, because technically speaking, the HS34 can do almost everything with just a receive-only feed from the 430"
HTH :)
Jake J
The link above should have all the answers you need, but, in short, bugs and GPSS and GPSV aren't output by the HS34.
