HS34 ARINC 429 Labels
henrysamson
Hi,
I have a D10A and an HS34 in my experimental. Works great using the two serial channels. One accepts input from an IFly GPS and the other is bidirectional and connected to a VAL429 VOR/ILS receiver. I am adding a Garmin 300XL GPS using the ARINC 429 capability of the HS34. The HS34 receives the data from the 300XL fine. It also receives the altitude directly from the D10A. The Garmin allows for options on the data it receives from the ARINC 429 interface; course, heading, or course and heading. The 300XL is receiving the course but does not receive the heading. I see lots of links to the HS34 ARINC 429 output labels in the forum but the links do not work. Does anyone know if the HS34 outputs heading? All of these tests are with the aircraft stationary. I have read somewhere that it outputs all labels that it has data for and heading is definitely one of them but would like further information to diagnose this problem.
Thanks!
Henry
Sorry about that. Our wiki went to internet heaven, but we're hoping to have a better self-service information center soon. Here's the info you were looking for from that page:
ARINC-429 Labels Transmitted by the SV-ARINC-429​
100: Selected Course
101: Selected Heading
102: Selected Altitude
203: Pressure Altitude
204: Baro Corrected Alt
210: True Airspeed
211: Total Air Temperature
320: Magnetic Heading
147: Magnetic Variation
ARINC-429 Labels Received by the SV-ARINC-429​
34G: VOR/ILS Frequency
114: Desired Track, True
115: Bearing to Waypoint, True
116: Cross-Track Error
117: Vertical Deviation
121: Roll Command
125: Time
147: Mag Var
173: Localizer Deviation
174: Glideslope Deviation
222: VOR Bearing
251: Distance to Go
260: Date
261: GPS Discrete Word
310: Latitude
311: Longitude
312: Ground Speed
313: Ground Track True
326: Lateral Scale
327: Vertical Scale
351: Distance To Destination (Via Flight Plan)
371: Equipment ID
377: Equipment ID
ARINC-429 Graphical Flight Plan Labels Received​
74: Flight Plan Header
75: Active Waypoint From/To Data
113: Message Checksum
300: Station Type / Class
301: Message Characters 7 - 9
302: Message Characters 10 - 12
303: Message Length, Type, Number
304: Message Characters 1 - 3
305: Message Characters 4 - 6
306: Nav/Wpt/Ap Latitude
307: Nav/Wpt/Ap Longitude
330: Conic arc Inbound Course
331: Conic Arc Radius
332: Conic Arc Course Change Angle
333: Airport Runway Azimuth
334: Airport Runway Length
335: Holding Pattern Azimuth
340: Procedure Turn Azimuth
That's a slightly different list, although my most immediately available documentation (from our old wiki) is missing the GPS receive side:
ARINC-429 Labels Transmitted by the HS34​
100G : OBS Value
203: Pressure Alt
210: True Airspeed
Basic ARINC-429 Labels Received by the HS34​
For NAV Radio​
034G: VOR/ILS FREQUENCY (BCD)
100: OBS Value
173: LOCALIZER DEVIATION
174: GLIDESLOPE DEVIATION
222: VOR OMNIBEARING
