KRichcreek
I am wiring my SV-Intercom-2S and my HS34 along with my FlightDEK-D180 with AOA. The HS34 installation shows a voice output at pin number 25 and the FlightDEK-D180 shows an AOA Alert Audio Output at pin number 18 of the DB25 connector. Page 4-10 tells me that I should only connect the audio output from the HS34 with a variable resistor.
My question is, with the Dynon intercom, do I still need to connect an external variable resistor (Radio Shack P/N 271-1715) prior to the intercom or can I connect the audio output of the HS34 directly to either pin 17 or pin 4 of the SV-Intercom-2S? The intercom wiring diagram shows a direct connection.
Will I get AOA alert audio with only the HS34 audio out connected?
