I have finished wiring the HS34 into my system and have a couple of quick questions:
System has D100, D120, SL30 and 496, I have SL30 serial TX and 496 serial TX connected into the two serial RX inputs on the HS34, I also have the 496 serial TX connected into the SL30 RX input for comms frequency upload. Do I need to also connect the HS34 SL30 serial TX to the SL30 and if so do I just connect the two inputs (HS34 and 496).
Second where is the menu item to select and test the voice outputs from the HS34 that are referenced in the EFIS manual (a menu flowchart would be a useful appendix in the manuals)
