Werner_Schneider
- Joined
- Mar 23, 2005
- Messages
- 136
Hi Dynon,
as we have "not yet" a HS34 Forum I post it here.
I did read through the HS34 description and I have some more questions:
-if I have a GPS who can only supply ARINC 429 data will the HS34 be able
to convert that ARINC data in order that an EFIS or EMS will be able to
understand it for HSI/wind purpose?
-Does the HS34 provide the ARINC stream from above on a serial port in
a NMEA format as output?
-consider the GPS on the HS34 and the SL-30 directly on the EFIS, does the
HS34 provide the GPS stream via DSAB to the EFIS so I no longer need
a switch to toggle between SL-30 and GPS? Or even better can I hook
up all (SL-30 and GPS) to the HS34 and all goes then via DSAB?
Many thanks for some answers which gives some more insight in the functionality
of the HS34 and might I suggest to open a forum for that unit
Werner
Werner
