Hello Dynon,
I have been using a 430 with an HS34 and both a D10a and D100 (as well as an EMS10.) Untill we recently refitted (after a warranty repair) the 430 , both the VOR and GPS info were being recieved by the HSI satisfactorily. However the HSI now believes we have 3 GPS's (but only gets a signal on the 3rd) and whilst it recognises that there is some VOR input it does not display frequency inputs nor any nav info.
We also have a TruTrak auto pilot so some settings at low for this.
We have the following settings on the GPS:
MAIN ARINC 429 SETUP
IN 1 HIGH EFIS/AIRDATA
IN 2 LOW OFF
OUT LOW GAMA 429
SDI COMMON
VOR / LOC / GS ARINC Config
RX TX
SPEED HIGH HIGH
SDI COMMON
DMI MODE DIRECTED FREQ 1
From the D10A (the primary unit) we have set up the HSI as follows:
HS 34
ANALOG INPUT ENABLED N
SERIAL
SERIAL 1
INPUT AVIATION
OUTPUT NONE
BAUD RATE 9600
SERIAL 2
INPUT NMEA
OUTPUT NONE
BAUD RATE 9600
ARINC SETUP
INPUT 1 GAMA GPS
INPUT 2 GAMA NAV
SPEED LOW
OUTPUT
OUTPUT DATA ON
OUTPUT SPEED LOW
As I have been setting this out it has occured to me that my mistake relating to the GPS 1 & 2 is probably in the serial inputs .....am I right in guessing that these need to be set to NONE?
I would appreciate your feedback on th GPS and the VOR set up at your convenience.
Many thanks
Henrik
IN 2 LOW OFF
OUT LOW GAMA 429
SDI COMMON
RX TX
SPEED HIGH HIGH
SDI COMMON
HS 34
SERIAL
SERIAL 1
INPUT AVIATION
OUTPUT NONE
BAUD RATE 9600
SERIAL 2
INPUT NMEA
OUTPUT NONE
BAUD RATE 9600
ARINC SETUP
INPUT 1 GAMA GPS
INPUT 2 GAMA NAV
SPEED LOW
OUTPUT
OUTPUT DATA ON
OUTPUT SPEED LOW
Many thanks
Henrik
