dodsond
- Joined
- Aug 9, 2006
- Messages
- 76
Just today I had an interesting failure that I hope to track down easily, but I am not sure if it is a wiring failure or something internal to a device.
I have a D-100, HS34, and Garmin 530. Everything had been working fine for 800 flight hours, until today.
Today, the HSI shows a groundspeed of 999 kts all the time. Of course, this gives me a 99 kt wind vector too.
DTW starts out at 1044 or so but counts up and down. The course pointer looks correct but the CDI is way off. At the bottom, I get a boxed T on the left and 33.0nm on the right. As the 530 sequences a waypoint, the HSI pointer does not change course. The ground track triangle will be accurate, then jump to a bogus course, then back to accurate periodically.
With VOR selected, similar course pointer and CDI behavior occurs.
All data and graphics on the 530 are accurate. It looks like OBS selection is passed to the 530 correctly.
The knobs on the HS34 seem to perform their correct functions (baro, heading, and course select when in OBS or VOR).
Lastly, the flightplan gets passed to my Garmin 496 correctly.
Any suggestions? Can a wiring problem cause this or is it likely a problem with the 530, HS34 or D-100?
Any help will be appreciated.
