Hi - we have just finished building an RV-7 and have just ordered a D100 and D120 with Garmin 396 GPS. (Comm provided by SL-40). While this is ideal, we have provided room to upgrade for IFR later, and will probably get an SL-30 and/or other equipment as necessary (HS-34, DME, MKR Beacon, backup attitude).
I just have a couple of questions regarding before and after the upgrade:
1) With basic installation (without HS-34) - can I easily set the CDI and heading bug through the button menu's (or can course be set through the GPS ?). I am used to having turn dials similar to the HS34 which are very quick and easy to use for everything including VFR flight. Is there a plan for the future to have a "simple" type HS-34 that is a lot cheaper and is basically 2 or 3 dumb dials? [this would make the cost much easier to justify, although maybe not upgradable to marker beacons]
2) For IFR, I would be getting the HS-34 and SL-30. Does the D100 display BOTH nav sources (active and backup) in the SL-30 as single pointers on the HSI ?
3) I understand GPS and NAV can't be used at the same time on the HSI, however can GPS distance be used in place of DME while a NAV source is selected? Is there a way to automatically select the DME/GPS distance based on the frequency entered into the SL-30? (for a paired VOR/DME ?) ....this might be a question for other pilots.
4) For marker beacons, is an alternative unit needed which then hooks into the HS-34 or can the 75mhz antenna be hooked "directly" in. Is there a hi/low sensitivity feature on the D100 or D120 ?
Sorry if the questions are confusing - and thanks for all your help on the forums !
