I have an EFIS-D100, D10A and an HS-34. My nav com is an SL-30 and the GPS is a 496. I intend to have the HSI displayed on the D10A and the D100 will be the EFIS, which is also the DSAB master. I spend the afternoon testing all the connections and found a few problems.
* If I have the HSI on the D10A only, the NAV SRC button on the HS-34 works as expected, but the BRG SRC button does nothing. I have to bring up the HSI on the D100 for it to work.
* Even when the HSI is dispalyed on the D100, pressing BRG SRC works sporadically. It often just flashes the current bearing source but does not stay on long enough for me to select anything. This is most noticeable when I also have the HSI displayed on the D10A. Sometimes it works OK, sometime not.
* If I monitor the standby NAV on the SL-30, the pointer on the HSI is erroneously aligned with the active VOR pointer. If I power off the HS-34, it then points correctly.
Kevin
Kevin
