khorton
Now that I know that I will be able to feed an HSI with GNS 430 VOR/ILS data, I'm starting to study the details of the HSI implementation. I have a few questions/comments:
1. If the GPS is providing data to the HSI, there is a text field for "ALT". What is the source of this altitude? GPS? If it is GPS altitude, what useful information does it provide the pilot given that ATC expects us to fly barometric altitude, which may differ by several hundred feet from GPS altitude? If it is barometric altitude, why do we need it on the HSI? I think this field is just useless clutter.
2. Would it be possible in a future update to display the TO waypoint ID? This is very useful information.
3. Why display "DTW" next to the distance to the GPS waypoint? This seems like clutter. The "NM" after the number makes it clear that it is a distance.
4. Why not use more standard abbreviations? Most EHSIs on type-certificated aircraft would use "BRG" instead of "BTW", "DTK" (desired track) instead of "CRS" (course). Course is quite ambiguous without an adjective, as it could mean current course, or desired course.
5. Why display 5 dots on each side of the CDI? Generally speaking, HSIs on type-certificated aircraft would display two dots, with the first dot at half-scale deflection, and the second dot at full-scale deflection.
6. Time to go ("TTG") to the next waypoint is also useful info, so it would be nice to be able to display it.
7. The wording in the manual is a bit confusing in the section about Course Indicator. It talks about the "course heading" that the GPS is reporting. Actually, that is the desired track. The GPS has no idea what heading you will need to fly to achieve that track, as it has no idea what the winds are.
Thanks for making the HSI mode.
