I had the whole instrument panel pretty much done, everything worked. Then I wrapped it.
I pulled everything out of the front that could be (HDX, OLED COM and Intercom) and pulled everything else from the back (prop controller, breakers) so each item remained pretty much in place, electrically connected.
After installing the vinyl and reconnecting all devices, I now have a very distinct hum in the audio. Gets MUCH worse when hitting TX. I also noticed on first boot that the radio was stuck in RX mode, but a second boot seemed to fix that. Odd. Changing the Dynon Dim Offset to -3 or +7 removes the hum.
Anyway, I've done the "touch a wire between the HDX case and the intercom case, hum will disappear" test. It didn't.
I traced all ground wires back to the central grounding block about 12" away: the HDX and EMS were connected to one pin. The OLED COM and Intercom panels were connected to another pin. Disconnecting all 4 of these, all devices remained powered on, so all devices appear to grounded to, getting ground path, from being mounted in the instrument panel? Connecting all of these ground wires only to each other, no change.
Doing a continuity test between the HDX case, the OLED COM panel case and connector shell, the Intercom panel case and connector shell, and the airframe all give a positive beep.
I don't know if this is the desired result, or if one of those test points should be isolated from the airframe.
Also noteworthy: when powering off the Intercom by pressing it's volume knob, then powering it back on, the OLED COM panel reboots. I hooked up the old LCD COM panel and it does NOT do this. I can't help that this is a symptom trying to tell me something, but maybe that's just how the new OLED COM panels are?
Tips please? What's supposed to be airframe grounded vs grounded to each other vs isolated? Should all Dynon devices remain powered on when their ground wires are disconnected?
I've been building for 700 hours and I've never been this frustrated.
