Maybe we can take care of them on one post.
1. After initial run-up and a taxi test, my cylinder 1 CHT reads 99 deg. with the engine not running, as opposed to the others at a 66 degree ambiant temperature. Did taxi test cause a CHT probe to destruct? The engine sounded fine.
2. Oil temperature configuration:
The "LO GRN/YEL: and the "BOTTOM YEL": can only be set down to 80 and not below. My Superior IO-360 says, "Do not start run-up until the oil temperature is 75 deg or above". I was wanting to have a yellow line from "0 deg" to "75 deg" so I could accuratly determine the Run-up temperature. Is there something I can do to set the config to below 80?
3. I cannot find anything in my engine manual that leads me to calibrating the EGT numbers and scale. Is there anything out there that can lead me down a reasonable EGT configuration path? I have read the post regarding the calibrations already in the EMS are not to be followed.
Thanks for your help.
Carl Nank
Carl Nank
