Denok
I would like to have the "VFR only" restriction removed from my aircraft for IFR use. I currently have a 10' Skyview touch with a GNS-430W. I know that a second HSI, in the form of an additional 7' Skyview classic will be needed for redundency as per Transport Canada regulations and knowing that CAR 605.18 states:
(j) sufficient radio navigation equipment to permit the pilot, in the event of the failure at any stage of the flight of any item of that equipment, including any associated flight instrument display,
(i) to proceed to the destination aerodrome or proceed to another aerodrome that is suitable for landing, and
(ii) where the aircraft is operated in IMC, to complete an instrument approach and, if necessary, conduct a missed approach procedure.
In the event that the GNS-430W fails, can I manage the above requirement with the Skyview only with all IFR fixes in the database knowing that Canadian geo-referenced approach charts are not available on Skyview. Non TSO'd equipment is acceptable but not Ipads. I will also need ton convince TC which will not be an easy task.
