I have a D10-A with the latest firmware version installed in my Cessna 172XP. The aircraft has just returned to service after 3 months down time during which a new engine was fitted. On powering up the D10-A all indications were normal except the altitude showed -1200ft. Adjusting QNH made no difference to the indicated altitude. When flying, all other indications on the Dynon (airspeed, bank angle etc) were as expected but the altitude stubbornly indicated -1200ft. The aircraft is hangared so is well protected from weather and, as all other pitot-static instruments worked, I suspect the pitot-static system is properly operational, not blocked etc. What do you think the problem may be and what should I do about it? If you think the altitide sensor is U/S, is it likely your Australian agent, Horsham Aviation Services, can fix the unit or will it have to be returned to you in the USA?
Many thanks and have a great New Year,
Peter E
Australia
Peter E
Australia
