My EMS-D10 voltage reading is showing 0.9 volts lower than the actual voltage. I measure 14.6 volts across the battery terminals, but the D10 shows 13.7 volts. I also measure 14.6 volts from the buss and ground where the D10 is connected. I even measured the voltage across the D10 buss and one of the extra unused ground wires out of the D10 which is used for other sensors. All readings show 14.6 volts while the D10 shows 13.7 volts. By the way, I have confirmed the 14.6 volt reading with two different meters.
Is this normal? Will this interfere with the sensor readings? All the latest software upgrades have been done. I have not noticed any other problems.
Thanks!
Tim
Thanks!
Tim
