Installing GRT Hall Effect Amp Transducter on D180
Bibendum
Hi
I would like to use Hall Effect Amp transducter for GRT to use with my D180.
Wich model can we use ? CS01 or CS02 ?
Must it be configurated in D180 ?
It says in D180 installation guide that output of CS01 must be set to pin 24 (Amps Hight Input), that ok but the sensor need to be connected to 4.8V power, so where must we connect it ? On pin 18 from DB37 ? It's 5V here.
Thanks for your help.
CS-01.
Yes it must be configured as sensor type 2 in the D180. The D180 have a 5V line you can use for power (pin 18)
